How to generate quadrature data
I'm using Measurement Studio 2012 Professional and need to generate a sine wave with quadrature output (idealy with a little noise thrown in).
I've examined the SignalGenerator class and cannot find how to have it generate complex data. I understand I can create a complex data type and load the real component but I would prefer real phase and magnitude components.
Can anyone steer me in the right direction please.
Regards
(5,911 Views)
Hey Frank334,
What specific functions have you been looking at?  Have you checked this out at all?
SineSignal Contructor: http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/bb7ebfe3/
Myriam D.
(5,890 Views)
Hi Myriam
SineSignal and SignalGenerator functions look perfect, except I cannot find how to make them generate complex data.
I require true complex not just loading a complex array with reals from SignalGenerator and zeroing the imaginary.
Is there a way to have a signal generation function producde complex data?
For now if written a method using sin/cos etc. but would much prefer to use a measurement studio function.
Regards
Frank
(5,886 Views)
Hey Frank334,
I did some more research into complex data types in Measurement Studio and found the following information, which may be a good place for you to start.  There is a ComplexWaveform class available, which supports the ComplexDouble data type.  The ComplexDouble Structure should let you define complex data by phase and magnitude.
ComplexWaveform Generic Class: http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/cd111482/
ComplexDouble Structure: http://zone.ni.com/reference/en-XX/help/372636F-01/mstudiowebhelp/html/b847c3b9/
Myriam D.
(5,869 Views)
Hi Myriam
Thanks for your continued effort.
From what I understand the ComplexWaveform class is simply a complex number repository and allows various ways of manipulating and extracting whatever you put in.  Looks quite useful but does not do what I need on this occassion.
I was hoping the MS library would have a simple signal generator that output in complex (I/Q) rather than reals. It seems this is not a common thing to do as there does not appear to be any support for this - pity, as there does seem to be excellent support for general signal generation.
Thanks again
Frank
(5,866 Views)
