How to get to autoscale check in "Color map style" measurement studio 3d graph in VB.net 2005
For the axcwgraph3d I can edit via the properties page the plots>>style>>color map style>>edit>>autoscale check box.
So how does one get to this check box programmably?
I'm using MS visual studio 2005
thanks
Bob
(3,284 Views)
Hi Bob,
In order to change the Auto Scale property programmatically, you just need to find the correct property function. The following function should get you going:
AxCWGraph3D1.Plots.Item(1).ColorMapAutoScale = True
(3,265 Views)
