How to install NationalInstruments.VisaNS.dll in Measurement Studion for VS2005
Hi All
I have installed National Instruments Measurement Studio tools for Visual Studio 2005.
Under the DotNet Software it installed "NationalInstruments.Common.dll" and
I also need "NationalInstruments.VisaNS.dll"  for my application.
How can I install  "NationalInstruments.VisaNS.dll"?
(6,999 Views)
Hello -
You can download the latest VISA driver from here. Once you have downloaded the driver, run the installer, and make sure you have selected to install .NET Framework 2.0 Languages Support.
Once you have done this, you will have the VisaNS assembly on your system.
NickB
Message Edited by nickb on 07-13-2009 08:13 AM
(6,978 Views)
The instructions say that I need NationalInstruments.Common.dll and NationalInstruments.VisaNS.dll to be able to communicate with oscilloscope.
I have installed NI-VISA from http://www.ni.com/download/ni-visa-18.0/7597/en/, however I am not able to find NationalInstruments.VisaNS.dll in the installation folder.
My requirements are Windows Embedded 7 (32-bit) + .Net 2.0. Where can I find correct libraries?
(3,733 Views)
VisaNS was deprecated in 2013 and superceded by VISA .NET. I've included a couple links below that provide more info on it. However, if you have further questions, I would recommend opening a new thread on the forums so it gets more visibility since this thread is almost 10 years old.
https://forums.ni.com/t5/Measurement-Studio-for-NET/NationalInstruments-VisaNS-dll-for-Visual-Studio...
http://www.ni.com/pdf/manuals/374899f.html
Applications Engineering
(3,711 Views)
