How to make the X axis to the middle position of graph in WPF?
(2,602 Views)
Accepted by topic author xPlus
Using the same technique as WPF Intensity Graph Change ColorScale Orientation, you can control the display location of the X axis using a ScaleHost.
In XAML, you would disable the standard display of the horizontal axis by setting Location to None, and add a scale host to the Children collection of the graph:
<ni:Graph x:Name="graph" DefaultInteraction="PanVertical">
    <ni:Graph.Axes>
        <ni:AxisDouble x:Name="xAxis" Location="None" Orientation="Horizontal">
            <ni:AxisDouble.MajorDivisions>
                <ni:RangeLabeledDivisions Mode="AutoWithoutExtremes" />
            </ni:AxisDouble.MajorDivisions>
        </ni:AxisDouble>
        <ni:AxisDouble x:Name="yAxis" Orientation="Vertical" />
    </ni:Graph.Axes>
    <ni:Graph.Children>
        <niPrimitives:ScaleHost x:Name="xAxisHost"
                                niPrimitives:LayeredGraph.TargetOrientation="Horizontal"
                                niPrimitives:LayeredGraph.TargetPosition="Far"
                                niPrimitives:RelativePanel.RelativeWidth="1.0"
                                niPrimitives:RelativeCartesianScalePanel.IncludeOverhangInSize="False"
                                Owner="{Binding ElementName=graph}"
                                Scale="{Binding ElementName=xAxis}"
    </ni:Graph.Children>
</ni:Graph>
In code, we can monitor the vertical axis for changes, and re-position the scale host to match:
public partial class MainWindow : Window
    public MainWindow()
        this.InitializeComponent();
        // Listen for changes the the vertical axis.
        var dataMapper = this.yAxis.GetDataMapper();
        dataMapper.DataMapperChanged += this.OnDataMapperChanged;
        this.OnDataMapperChanged(dataMapper, null);
    private void OnDataMapperChanged(object sender, DataMapperChangedEventArgs e)
        var dataMapper = (IDataMapper<double>)sender;
        // Position the horizontal axis at the origin of the vertical axis.
        double relativeOrigin = dataMapper.Map(0.0);
        RelativePanel.SetRelativeVerticalPosition(this.xAxisHost, relativeOrigin);
        // Orient the axis to maximize label visibility.
        if (relativeOrigin <= 0.5)
            LayeredGraph.SetTargetPosition(this.xAxisHost, RelativePosition.Far);
            RelativePanel.SetRelativeVerticalAlignment(this.xAxisHost, RelativeAlignment.Near);
        else
            LayeredGraph.SetTargetPosition(this.xAxisHost, RelativePosition.Near);
            RelativePanel.SetRelativeVerticalAlignment(this.xAxisHost, RelativeAlignment.Far);
~ Paul H
(2,573 Views)
