How to multithread to start a method that controls an led
I'm working on a search program and would like to have a national instruments led control blinking during the search. The led needs to be started on its own thread while the search runs on a separate thread. This is my first attempt at multi-threading in c# and I'm not sure what to try.
Here is my c# code, I'm trying to start the LED blinking then run the search then stop the LED blinking. The LEDON() and LEDOFF() work if run separately.
Code:
private void btnSearch_Click(object sender, EventArgs e)
            Thread LEDStart = new Thread(LEDON);  //Creates a Thread that will call LEDON()
            LEDStart.Start();
            int i;
            string temp = "*" + textBoxFileName.Text + "*";
            string[] AllFiles = Directory.GetFiles(this.textBoxFolderpath.Text, temp, SearchOption.AllDirectories);
            for (i = 0; i < AllFiles.Length - 1; i++)
                progressBar1.Maximum = AllFiles.Length - 1;
                string[] row = new string[] { Path.GetFileName(AllFiles[i]), AllFiles[i] };
                dataGridView1.Rows.Add(row);
                progressBar1.Increment(1);
                if (progressBar1.Value == progressBar1.Maximum)
                    Thread LEDEND = new Thread(LEDOFF);  //Creates a Thread that will call LEDOFF()
                    LEDEND.Start();
        //Turn On LED
        private void LEDON()
            if (this.led1.InvokeRequired)
                this.led1.Invoke(new MethodInvoker(() => LEDON()));
                return;
(3,908 Views)
Looks like my code got cut off, here is the complete code:
            Thread.CurrentThread.Name = "LEDON";
            LEDStart.Start();
            int i;
                    //Thread.CurrentThread.Name = "LEDOFF";
                    LEDEND.Start();
        //Turn On LED
        public void StartLEDON()
            //Thread.CurrentThread.Name = "LEDON";
            LEDStart.Start();
        public void LEDON()
                return;
            led1.BlinkMode = NationalInstruments.UI.LedBlinkMode.BlinkWhenOn;
            led1.Value = true;
        //Turn Off LED
        public void LEDOFF()
                this.led1.Invoke(new MethodInvoker(() => LEDOFF()));
                return;
            //led1.BlinkMode = NationalInstruments.UI.LedBlinkMode.BlinkWhenOn;
            led1.Value = false;
(3,894 Views)
Have you taken a look at the multithreading whitepaper that goes over multithreading in CVI?
https://www.ni.com/en/support/documentation/supplemental/06/multithreading-in-labwindows--cvi.html
Additionally, there is an example that goes through how to do multithreading in CVI.
http://www.ni.com/example/29662/en/
Do you have a more specific questoin?
Brandon Grey
Certified LabVIEW Architect
(3,865 Views)
