How to pass an enum from Test Stand
Is it possible to pass an enum in from TestStand ? If not I will have to make it into a string and do compares on my cases but it would be handy if I could ?
The compiler has mentioned
Error 1 Inconsistent accessibility: parameter type 'ChamberClass.Chamber.ChamberName' is less accessible than method 'ChamberClass.Chamber.Initialise(NationalInstruments.TestStand.Interop.API.SequenceContext, ChamberClass.Chamber.ChamberName, int, out bool, out int, out string)
The enum (highlighted) is declared in my class and so I could understand why it wouldn't like it but just on the off chance that there is a solution ? ..
(5,635 Views)
Accepted by topic author LizzardSB
Fixed ! No need to reply:- Once again it wasn't a test stand issue: it was because my enum was private...
(5,625 Views)
