11-26-2006 10:52 PM
I am new in C# programming. Currently I am developing a program using C# language and Measurement Studio 7.1. This program will use for signal processing. So, may I know how to plot 3D graph (waterfall) in my program? I notice that only 2D graph available in Measurement Studio. Thanks for your help!
11-27-2006 03:12 PM
Hi Wesley,
The following links will get you up and running:
Creating Intensity Graphs in .NET using the Measurement Studio 3D Graph ControlUsing Plot Styles with the Measurement Studio 3D Graph Control
There is no C# Assembly for 3D Graphs, but you can get the same functionality combining the C++ code as in the top example.
05-27-2011 07:43 AM
Thanks David.
Is there any exemple running under VB-2010?
I'm having trouble running the 3d chart graph on MS2010.
Thanks in advance.
06-08-2011 09:55 AM
Hi Ni community :
No idea how to perform a 3d chart on MS2010 -vb.net- under 64 bits?
Is it in your plans for future releases ?
thanks in advance.
09-07-2011 09:20 AM
Any update?
09-07-2011 04:05 PM
Elbob,
Sorry for the lack of response. Unfortunately, you are correct, the 3D graph for Measurement Studio is the ActiveX version that is not 64-bit compatible. If you need a 3D graph in 64-bit then you can use the intensity plot, but this only produces 3D data in a sense that color is the third dimension. Currently Measurement Studio does not have an equivalent to the ActiveX 3D graph control. I don't really have any information to provide on future support of this feature, but I would recommend taking the time to place a product suggestion for it. Our development teams typically look at these as the primary source when considering new features.
