How to read all samples at once before memory is overwritten in PXI 5105 in .Net (C#, VB)?
Hi
I have NI PXI oscilloscope 5105 card with following specifications, but it is bit slow when I try to read one sample at a time.
I need to read minimum voltage for each revolution of my angular encoder [Z index pulse]. Can you please guide me how I can start Oscilloscope and read all samples at the end?
Samples to acquire and timeout is not fixed and varies.
Is there any way so that I can read all samples at once before oscilloscope overwrite memory? How I can send stop and read all samples command to oscilloscope and oscilloscope should not flushes the data? The problem is that when I tried to read all data then there is an error, which is saying that oscilloscope memory has been overwritten and data is not available to read.
Analog signal is connected with Channel 0.
Sample Rate="10000000"
Input Impedance = 1000000.0
Maximum Input Frequency = 10000000.0
Sample Length="3000"
Enforce Real time = true
Samples to acquire = 650
Trigger Level="-0.545"
Trigger Slope= "Negative Analog Edge "
Vertical range 10 V
Reference Position = 5
Message 1 of 1
(2,310 Views)
