How to remove trailing zeros using EngineeringFormatInfo?
HI,
I found a measurement studio formatter for SI notation.
For details, see the NI document.
Here, I want to know how to remove any trailing zeros. I could not find any information about this.
For example,
code : string result = string.Format(EngineeringFormatInfo.Default, {0:s5}, double value)
if  value = 1.2345678E-3,  result is 1.23457E-3. It is ok.
if  value = 1.2E-3,  result is 1.20000E-3. But I want to get "1.23m".
In labview, I usually use "%#.5p" format string.
(7,232 Views)
@diluculo wrote:
HI,
For example,
I don't understand how you are getting 1.23457E-3 ?  And claiming that is okay.
If you are using the format string that you claim you are using, then you should be getting 1.23457m.
It sounds like you are using string result = string.Format(EngineeringFormatInfo.Default, {0:E5}, value)
(7,228 Views)
You are right. i mistyped.
Anyway, my question is "Is there any way to remove zeroes in using EngineeringFormatInfo?"
(7,224 Views)
code : string result = string.Format(EngineeringFormatInfo.Default, {0:s5}, value)
value = 1.2345678E-3 -> result = "1.23457m"
value = 1.23E-3 -> result = "1.23000m". But I want to get "1.23m" without trailing zeros.
(7,223 Views)
Based on the documentation page you linked, the answer is no.
(7,221 Views)
So, unfortunately, there is no native way to format numbers in metric units even in the Measurement Studio.
Thanks.
(7,217 Views)
I believe the formatter is working as expected, treating the value as containing five significant digits after the decimal (including trailing zeros). Using scientific notation, the value 1.23000 indicates a more precise value than 1.23 with the trailing significant digits removed.
Unfortunately, I do not know of any existing format mode that supports a "maximum digit count" (they either show all digits, or an "absolute digit count").
~ Paul H
(7,187 Views)
