How to setup a certain sample rate / callback rate with network based devices.
Hi all,
i am using C# with usb based cDaq frames quite a lot, but recently I had to use network based devices. They had 2 modules onboard:
1.  9239 BNC
2.  9239 BNC
The signals I am measuring aren't that fast thus I would like get a callback every 10 seconds. But whatever I tried I can't seem to get that to work with the network based devices. The seems to be giving samples (and callbacks) as fast as it can run. No matter which timing mode , sample clock rate i pass to.
Is there a way to setup them up that the do a sample per 10 seconds? I now created a dirty fix for it, but there must be a correct way to set this up 🙂
Per
Message 1 of 1
(1,815 Views)
