How to transfer a large file over GPIB
Hi Guys,
I am struggling with automating the instrument box.
what I am trying to do here is transfer a large file over GPIB. however, it seems the largest file I could transfer is about size of 2.2 MByte. any file larger than that will "timeout" and leave a incomplete file of size 2.2MB on the disk.
I am using public void Write(byte[] data); byte[] contains the SCPI command and the filestream in byte[] format.
could
        public IAsyncResult BeginWrite(byte[] buffer, int offset, int count);
        public IAsyncResult BeginWrite(string buffer, AsyncCallback callback, object state);
works...I couldn't find any documentation so I am not sure how to use them. Any sample code I can take a look? Appreciated!
Any suggestion?
Thanks.
(4,333 Views)
Hello Leon.x.Chen,
What instrument are you using? What is the size of the file you are trying to transfer?
Miriam
Field Applications Engineer
NI Colombia
CLD
(4,320 Views)
Thanks for your response.
I am using CMW500. and the file I am trying to transfer now is around 6MBytes. but in future we will transfer file of size up to 1GBytes.
Thanks again !
(4,316 Views)
