How to use DAQ-Assist in C# for PXI-5112
I want to develop program using C# for PXI-5112,
I install DAQmx Driver, so I can control the PXI-5112 using NI-Scope.
Then I a create measurement  -C# project,
In the step of add Class Library, I check all Item,
include DAQmx LIbrary
In the next step,I check "lauch the DAQmx Task wizard";
the click finish button,
I select "new Item"
then select Analog/ Voltage
Then "no supported device found", at this time, I can control the PXI-5112 by NI-Scope.
I want to konw whether PXI-device is supported by DAQ-assistant,
if supported, how to use it in C#, can you give me a sample if you can.
Thanks very much
(3,571 Views)
Hello 初学者
The DAQ Assistant works only with DAQmx devices. Sounds like you are using a scope, which is not a DAQmx device. If you want to program the 5112, check out this document for more information
Bilal Durrani
NI
(3,563 Views)
I can see the 5112 for PXI in Measurement  & Automation, and it is sorted in Traditional NI-DAQ devices, I can use the Test Panel to start 5112.
I consult NI china for the 5112,They reply that 5112 is not a DAQ device supported by DAQ-assistant,
Now, I don't know how to do.
(3,559 Views)
The KB I linked previously provides  wrappers you can use in C# to program your scope. You cannot use the DAQ Assistant, but you can still use the wrappers to create your application in .NET
Bilal Durrani
NI
(3,552 Views)
Bilal Durrani, Thanks very much. All is OK.
(3,544 Views)
