How to use ai/sampleclock
can anyone explain how to use "ai/sampleclock"?
I have an USB 6210 card and I want to read data from analog and digital in.
A very basic setup looks like this:
string dev = "dev1";
Task t1 = new Task();
t1.AIChannels.CreateVoltageChannel(dev + "/ai0", "", AITerminalConfiguration.Differential, -0.1, 0.1, AIVoltageUnits.Volts);
t1.Timing.ConfigureSampleClock("", 100.0, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples);
t1.Control(TaskAction.Verify);
Task t2 = new Task();
t2.DIChannels.CreateChannel(dev + "/port0/line0", "", ChannelLineGrouping.OneChannelForEachLine);
t2.Timing.ConfigureSampleClock(dev + "/ai/SampleClock", 100.0, SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples);
t2.Control(TaskAction.Verify);
I get an exception at the t2.Timing.ConfigureSampleClock call (also tried with "/ai/sampleclock", /dev1/ai/sampleclock")
Is it not possible to get analog and digital data at the same time with this card?
If I understand the forum posts correctly, I can't use the internal clock to get digital data (how can I check this with the Deviceinfo class?)
What clock source would I use if I only want to get digital data?
Kind regards
Stephan
(6,459 Views)
Hi StephanD,
the USB 6210 has no own internal sample clock. What are you trying to achieve with your application?
Regards
(6,441 Views)
Hi FrankLp,
I'm trying to read analog and digital data at the same time. For analog data this works as expected. But I don't know how to get digital data with my card.
Regards
S.
(6,425 Views)
Hi StephanD,
are you trying to read simultaniously? That means that you have to use threads or processes to get a parrallel execution. Without initiating that, you only got sequentiell execution of your code.
There are good Microsoft Knowledgbase articels on how to do threading in c#:
http://msdn.microsoft.com/en-ie/library/ms173178%28v=vs.80%29.aspx
Regards
(6,380 Views)
