How to use libraries for traditional daq with C#
I am having an issue using the axCWDIO library in my project to control a DAQPad-6508.Can anyone help?
I have an axCWDIO object on my form, have the properties set for output ports, and included the libraries axCWDAQControlsLib, CWDAQControlsLib, and CWUIControlsLib.
The problem is when I want to set specific lines to high (5v) it doesnt always set them.Havent been able to find anything in the documentation that comes with the NIDAQ (I used version 7.4.1) I dont know if this is really trying to write to a port instead of a line, perhaps thats my problem? Not only does it not set anything for some values of intcnt, it gives an error if I get too high (as if the highest is port.item(11) because there are 12 ports on a 96 bit version?) I also get an error reading after the first time.
Heres the basics of my code:
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Text;
using System.Windows.Forms;
using System.Threading;
using AxCWDAQControlsLib;
using CWDAQControlsLib;
namespace NIDaqTester
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
        private void button1_Click(object sender, EventArgs e)
            int ret = 0;
            object data = null;
            try
                for (int intcnt = 0; intcnt < 11; intcnt++)
                    ret = axCWDIO1.Ports.Item(intcnt).SingleWrite(5);
                    Thread.Sleep(50);
                    ret = axCWDIO1.Ports.Item(intcnt).SingleRead(ref data);
                    Thread.Sleep(50);
                for (int intcnt = 5; intcnt < 11; intcnt++)
                    ret = axCWDIO1.Ports.Item(intcnt).SingleWrite(0);
                axCWDIO1.Dispose();
            catch(Exception ex)
                axCWDIO1.Dispose();
                return;
(3,193 Views)
What kind of errors do you see?
Also have you tried changing the SingleWrite command to write a 1 instead of a 5? Usually digital logic only accepts a 1 or a 0, not the actual voltage.
I found this reference on Component Works which is what the axCWDIO object is based on. The documentation is not very complete but I found the Tutorials in Chapter 6 very useful. The other problem with this document is that it refers to VB code and not C#.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,170 Views)
