How to write from P0.8 to P0.15
Hello
I'm using this code for turn on the bits of Port0:
    Private Sub TURN_ON (ByVal Line_Name As String)
        Dim digitalWriteTask As New Task
        Dim writer As New DigitalSingleChannelWriter(digitalWriteTask.Stream)
        Select Case Line_Name
            Case "Line0"
                Try
                    digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line0", "port0", ChannelLineGrouping.OneChannelForEachLine)
                    writer.WriteSingleSampleSingleLine(True, True)
                    Exit Sub
                Catch exception As DaqException
                    MessageBox.Show(exception.Message)
                Finally
                    digitalWriteTask.Dispose()
                End Try
          Case "Line1"
       End select
End Sub
    Private Sub TURN_OFF (ByVal Line_Name As String)
            Case "Line0"
                Try
                    writer.WriteSingleSampleSingleLine(True, False)
                    Exit Sub
                Finally
                End Try
          Case "Line"
        End Select
    End Sub
BUT IT DON'T WORK FOR LINE 8....LINE15. WHY??
CAN YOU SEND ME A CODE EXAMPLE THAT TURN ON AND OFF ONE BIT AT TIME LINE 8....LINE15? THANKS
Message 1 of 12
(5,533 Views)
Message 2 of 12
(5,526 Views)
Message 3 of 12
(5,526 Views)
I know this doesn't solve your problem but you could reduce your code, both subs and all the select case code to one short sub.
Private Sub WritePort(ByVal Line_Name As String, ByVal Value As Boolean)
        Dim Line As String = Line_Name.Substring(Line_Name.Length - 1, 1)
        Try
            digitalWriteTask.DOChannels.CreateChannel("Dev1/Port0/line" & Line, "port" & Line, ChannelLineGrouping.OneChannelForEachLine)
            writer.WriteSingleSampleSingleLine(True, Value)
            'You don't need 'Exit Sub' here
        Finally
        End Try
    End Sub
Sorry this doesn't solve your issue
Curt
Message 4 of 12
(5,526 Views)
my problem is still unresolved...
What I must do for write from P0.8 to P0.15
Message 5 of 12
(5,514 Views)
I don't know what hardware you are using, but is it possible that there are two 8 bit ports on your device and not one 16 bit port?
If that is the case then try using something like this for bits 8 to 15
"Dev1/Port1/line0", "port1"
where line0 = line8 and line7 = line15
Curt
Message 6 of 12
(5,504 Views)
Hello peppepeazella,
in the following link you can find an example of how you can generate continuous analog waveform with variable rate internal clock using Visual Basic .NET
Continuous Analog Waveform Generation with Variable Rate Internal Clock in Visual Basic .NET
http://zone.ni.com/devzone/cda/epd/p/id/4775
I am also sending you a link where you will be able to find examples regarding DAQmx functions for .NET.
NI-DAQmx, NI-VISA and NI-488.2 .NET Example Locations
https://www.ni.com/en/support/documentation/supplemental/18/ni-daqmx--ni-visa-and-ni-488-2--net-exam...
Please let me know if this is of assistance.
Thank you,
Antonios
Message 7 of 12
(5,492 Views)
Sorry But I don't have found nothing that help me
I' have still the problem to drive P0.8 line
Message 8 of 12
(5,478 Views)
What type of device are you using?
Curt
Message 9 of 12
(5,475 Views)
Hello
my hardware is USB - 6212
THanks
Message 10 of 12
(5,459 Views)
