Howto Self-Test devices in NI-Max after powercycle
Hello.
How can I perform the "Self-Test" functionality from .NET?
For some reason I now after every powercycling of the NI9234 rack (both a 9191 and a 9184) I have to open NI MAX, and perform a self test on each device.
It takes a while (matter of seconds) the first time after a power cycle, reexecuting the selftest again is vary fast. There seems to be some software checking happening 🙂
So - how can I perform this "Self-Test" from C#.
Kind regards
(5,529 Views)
Hi Larover88.
It depends on what NI driver you are using. If for instance you are using the DAQmx driver, you can find the documentation here:
SelfTest Method
In order to call the SelfTest method, you need to create a Device.
Device Class
And in order to create a Device you can use the LoadDevice method.
LoadDevice Method
The final code for performing a SelfTest in DAQmx will look like this:
// Self test
Device dev = DaqSystem.Local.LoadDevice("cDAQ1");
dev.SelfTest();
Hope this helps.
Best Regards
Alex E. Munkhaus
Certified LabVIEW Developer (CLD)
System Engineer
(5,519 Views)
