.I have come up with an InvalidOperationException : the start up form doesn,t load."The error is:Mixed mode assembly is built against version v20.50727 of the runtime and cannot be loaded in the 4 .0 runtime without additional configuration information.
dear sir,
if you could please tell me what additional information is required and where these options are specified i'd be greatly appreciative of your good advice.
thank you kindly.
i am using VB2010 and Windows 10
(3,854 Views)
Accepted by topic author jeffreykap123
Hi jeffreykap123,
It sounds like you might be using code from an older .NET Framework version in your project while the project is set to use the 4.0 Framework. I'd recommend taking a look at the following articles from Microsoft regarding similar behavior. They should resolve that error message.
https://blogs.msdn.microsoft.com/jomo_fisher/2009/11/17/f-scripting-net-4-0-and-mixed-mode-assemblie...
https://msdn.microsoft.com/en-us/library/bbx34a2h.aspx
Charlie J.
(3,833 Views)
