ICE30 Errors when compile a WiX project and including the mstudiocommon.2010.msm
Hi B_Diel,
Thanks for the update.
Yep, I know about the GUID. Rest assured this is not my final application. I left the stuff there because I did not wish to change your code too much. Also, I saw a note somewhere indicating that setting the GUIDs that way could pose some issues. Also, I am unclear why two sets of GUIDs are required even if targeting two platforms with the same code.
As far as I can tell, both the VISA NS and Common dlls did get redirected when executing my code. Otherwise common dlls go to the GAC and visa goes to [TargetDIR]. I typically found the visa DLL under Merge Modules Folder if redirection failed. Kudos on fixing the MSMs for VS2012. I have not looked at your VS2012 examples -- I think I am going to skip that version seeing that VS 2013 is knocking on our doors already.
What version should I expected for visa32.dll under x86 Windows? And, what is the earliest visa32.dll version that works with, say, VISANS.2010?
BTW. I cleaned up the code so that I could do away with most of the Light and ICE error suppressions. Leaving only 1056 and ICE30.
I also took out the nimetautils -- seeing that it did not get installed with the VS installer, I assume it is not realy necessary as it just adds alerts and warnings.
Also seeing somewhere that C++ run time is not required for VISA (I believe one of the support engineers indicated that that is required for 3D graphics), I am ignoring the C++ msm. That took out another set of warnings.
All and all, this has taken quite a bit of work and I am not done yet....
David
Message 11 of 13
(3,221 Views)
  • visa32.dll will be the version of the NI-VISA that you installed on a 32-bit system.
  • NI-VISA 5.0.3 is the first version to include .NET 4.0 support.
  • Since you are only using NI-VISA and none of the other Measurement Studio libraries, it is safe to remove nimetautils.
  • The C++ run-time is a dependency of NationalInstruments.Common.Native.dll which is a dependency of NationalInstruments.Common.dll. You will see this in the ModuleDependencies table of the MStudioCommon.2010.msm.
Message 12 of 13
(3,215 Views)
Hi D_Biel,
Seeing how NI is standardizing on using WiX, will you be considering distributing wixlibs instead of or in addition to merge modules? If so, I am game for doing some testing on those.
The WiX libraries seem much easier to merge with the WiX installation projects. The cons are that they are specific to WiX.
David
Message 13 of 13
(3,188 Views)
