Incorrect Readings After Turning SCXI Unit Off and Back On
I have a weird problem.  If I run my program to log two thermocouples it works fine.  Then I can turn the SCXI chassis off and back on and the numbers will be incorrect (twice what they should be).  If I then stop my program and open LabVIEW to log the same temperatures, everything is fine.  Is there some sort of reset I need to do or a reconfigure or something?  Keep in mind that before I turn off the unit I stop my VB.NET program and I turn the unit back on before I restart the program.  Using SCXI-1000 with an SCXI-1125.
Good Readings
Bad Readings
Code:
While Channels(ChannelCount).Device = "SC1Mod1"
With Channels(ChannelCount)
If Not mod1TaskCreated(0) Then
Tasks(0) =
New Task("mod1task")
mod1TaskCreated(0) =
True
End If
Select Case Channels(ChannelCount).Type
Case Is = "Temperature"
Tasks(0).AIChannels.CreateThermocoupleChannel(.Device & "/" & .Channel, .Name, _
.Min, .Max, AIThermocoupleType.K, AITemperatureUnits.DegreesF)
Tasks(0).AIChannels(.Name).AutoZeroMode = AIAutoZeroMode.None
Tasks(0).AIChannels(.Name).LowpassEnable =
True
Tasks(0).AIChannels(.Name).LowpassCutoffFrequency = 4
Case Is = "Voltage"
Tasks(0).AIChannels.CreateVoltageChannel(.Device & "/" & .Channel, .Name, AITerminalConfiguration.Differential, _
.Min, .Max, AIVoltageUnits.Volts)
True
Case Else
MsgBox("Error in channel configuration!", MsgBoxStyle.Critical, "Warning!")
System.Console.WriteLine("Error in Channel Configuration. Abort.")
Exit Sub
End Select
End With
ChannelCount += 1
End While
Tasks(0).Timing.ConfigureSampleClock("", 10000, SampleClockActiveEdge.Rising, SampleQuantityMode.FiniteSamples, 1000)
Tasks(0).Control(TaskAction.Verify)
reader =
New AnalogMultiChannelReader(Tasks(0).Stream)
Task1Data = reader.ReadMultiSample(1000)
Thanks.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
(3,643 Views)
Problem solved:
Private dvc As DAQmx.Device
dvc = DaqSystem.Local.LoadDevice("SC1Mod1")
dvc.Reset()
(3,638 Views)
For discussion of why this situation arises please see this thread.
Thanks-
Tom W
(3,629 Views)
Thanks Tom.
(3,627 Views)
Not a problem- let us know if you run into anything else.
Thanks again!
Tom W
(3,625 Views)
