Install Error when trying to install Measurement Studio 7.0
I am receiving two erros when trying to install Measurement Studio 7.0:
"The installer cannot setup Measurement Studio for Visual C++ while Visual C++ is open. Please make sure Visual C++ is closed and click ok."
"Although you have the proper version of Visual C++ installed on your system, it is not configured properly. To correct this problem, run Visual C++ and exit it, then run this installer."
I am running Windows XP and have installed Visual Studio.net Academic Edition. Will Measurement Studio work with Visual Studio Academic Edition, or do I need the professional edition? What can I do to solve this problem?
(3,276 Views)
Hello
Are you installing the Measurement Studio support CD and having this problem? If you are using Visual Studio .NET 2003, you don't need to install the Measurement Studio support CD ( check my post here).
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,276 Views)
