Install Measurement studio
I am trying to install MS 8.1.1 I bought sometime ago.  I don't remeber if I installed it on any of my two computers. So I tried to reinstall.  However, I was told on both PCs that I need to remove the evaluation version first.  Does this means I have not installed it before.  In the start->programs->National Instruments I do see MS 8.1, but I can't tell if it is eval version or how to uninstall. I also can't find the program from the pc's control panel (MS is not listed here).
(3,993 Views)
Hi yan_santur,
Under Control Panel, you need to go to Add/Remove Software and then click on the National Instruments Software item. Then select Change/Remove which will bring up a National Instruments dialog indicating all the install NI software. Then select the Measurement Studio components and remove them.
Also check out the Viewing Installed Measurement Studio Items License Status KB which tells you where to go to find out what your license status is for Measurement Studio.
Best Regards,
Jonathan N.
(3,990 Views)
