InstallShield installation - Error 2705
I've had issues adding a couple of the NI merge modules to an Installshield 11 Profesisonal project as well.  I have measurement studio 7.  Every time I build installations Installshield complains and won't build the setup.  I thought I was doing something wrong but it now appears that there is a larger issue here if others are having the same problem.
I'll be bookmarking this thread because I still have one installation which still has to use the LabView run-time engine installer because I can't get a few of the merge modules to work in Installshield.  I don't mind using the run-time engine, but I would much rather the first company logo the customer sees is ours.
Message 11 of 37
(8,039 Views)
by the way, my log file does almost look exactly identical to the one of the original poster.
Thanks.
Message 12 of 37
(8,020 Views)
I think there might be a little confusion on this post because it seems like some people are having problems building the msi installer and others are just having problems installing.  Is this true?
As Jeff posted before, unfortunately we only have Installshield 9 here.  If it is possible to open an Installshield project from a previous version of Installshield in a newer version of Installshield, you could post your version 8 project on our ftp.  We can try and take a look at it here.  If you could also post the msi's generated by your project, we can take a look at those as well.  Because some projects install properly and others with installscript are not installing properly, you might want to also try and talk to support for Installshield, but again if you post the project with the MSIs we will be more than happy to take a look at them.  Our public ftp is ftp://ftp.ni.com/incoming.  I have created a folder called installshield.  If you zip up your project and msi's, we will take a look at them.  Please just name the .zip as whatever your DF name is.
Pat P.
Software Engineer
Message 13 of 37
(7,958 Views)
I sent my project through support email yesterday (sorry didnt see the ftp info)
it is an IS 8 project
Message 14 of 37
(7,943 Views)
Has any progress been made on this issue?
Message 15 of 37
(7,807 Views)
Chris.
I haven't heard of any fix for this problem. I have resolved it myself by adding in the files manually which is not ideal but fixes the problem.
Joe
Message 16 of 37
(7,801 Views)
Could someone from NI technical support please add an update regarding the current state of this problem?
My understanding was that investigations were delayed because NI only had InstallShield 9, whereas customers were using more up-to-date versions of InstallShield. However gbedford has sent an IS8 project file in which the error occurs.
Have NI support made any attempts to look at this InstallShield 8 project file? What were the results? Are National Instruments continuing to investigate this issue?
        regards,
                   Chris Williamson
Message 17 of 37
(7,763 Views)
this is reference Reference#7107349.
last i heard R&D was looking into it.
Message 18 of 37
(7,756 Views)
R&D is still investigating the issue.  As soon as we find anything we will post updates here.
Pat P.
Software Engineer
Message 19 of 37
(7,751 Views)
hello, could anyone tell me if any solution to this was ever found?
Thanks.
Message 20 of 37
(7,302 Views)
