Installing MS 8.0.1 help files receive Internal Error 2727. F1HELPDIR
I am using windows XP pro, Visual Studio 2005, and MS 8.0.1 and trying to install the help files, but I get this error every time.  When I go to use the F1 function of help for the classes in MS it comes up with "Information not found" along with a few steps to get the info to pop up, but no luck there either.
Has anyone received this message before?  Or, is there a certain sequence to installing everything?
Mtonsager
(4,753 Views)
Hi Mtonsager,
Thank you for the post.  We are looking into the best way to resolve this issue. Thank you for your patience.
Cheers,
David Goldberg
Software R&D
(4,737 Views)
Hi Mtonsager,
Please contact National Instruments via email so that we can resolve this issue for you.
Cheers,
David Goldberg
Software R&D
(4,726 Views)
Thanks for helping out.
I guess I only have the basic service so I am only able to use the discussion forums.  I am wondering if needed to have the msdn Library documentation installed before the MS 8.0.1 software?  I wonder if I should uninstall MS 801, msdn library, and VS 2005, then reinstall them?  What do you recommend being installed before installing MS 801?
Thanks again,
Mtonsager
(4,707 Views)
Hi Mtonsager,
If your email address is in your profile, and you give me permission to email you (just by saying so), I can email you directly.
Gavin Fox
Systems Software
(4,687 Views)
Sure, you can email me.  My email is in my profile.
Mtonsager
(4,683 Views)
I am having this same issue, but I didn't see a resolution since it was e-mailed to the requestor.  I am also having bad problems trying to install 8.0.1 both on the Measurement Studio side and Driver CD side.
I have an open support request for this (which might be in my profile), but they haven' t got back with me on a solution yet.  Could you also "e-mail me the solution"?
-Matt
(4,241 Views)
