Invert axis 3D graph bug
Has a fix been implemented with the 3d Graph Axis Invert bug?
Attached is a sample of the bug.
Double-click the graph to switch between 3d and XY plane projection.
Check the Invert check box to invert the X axis.
Move the mouse over the graph to view the current X, Y, and Z data.
The bug: Note that when you invert the X axis, the Z data is not also inverted. That is to say, at the bottom right of the graph, the values reported by the PlotMouseMove event are X=9, Y=29, Z=28 when the X axis is not inverted. When the X axis is inverted, the values reported by the PlotMouseMove event at the bottom right of the graph are exactly the same, even though the X axis has been inverted and the displayed graph has been inverted.
(3,214 Views)
This looks like a problem. I'll forward this to the developers for further investigation.
Using the cursors provides the correct coordinates with the axes inverted. That might work as a workaround for now. I aologize for any inconvienience this might have caused.
Message Edited by bilalD on 02-10-2006 10:32 AM
Bilal Durrani
NI
(3,210 Views)
