Is it possible to reserve an Ethernet cDAQ device in the software?
I am using an Ethernet device, but there will only be one PC connecting to it.  It is possible to reserve this device in software so I can eliminate that step for my clients.
Thanks.
Programming Data Acquisition and Control in Measurement Studio and Labwindows/CVI
Message 1 of 8
(6,661 Views)
Have you checked out the DAQmx Reserve Network Device.vi, under Measurement I/O -> DAQmx - Data Acquisition -> DAQmx Advanced -> System Setup? The detailed help on this VI says 'Adds a Network cDAQ device to the system and, if specified, attempts to reserve it.'
- Regards,
Beutlich
Message 2 of 8
(6,655 Views)
I'm using VB.NET.  I'm assuming a function exists, however, since LabVIEW has something.
Message 3 of 8
(6,653 Views)
Greetings,
what language are you programming in? Visual Basic, C#, etc?
Product Support Engineer
Message 4 of 8
(6,638 Views)
VB.NET
Message 5 of 8
(6,636 Views)
Oh, whoops, sorry about that. I misread what you'd originally said. I looked around in the object browser in Visual Studio 2010 and found a few methods that look like they're exactly what you're looking for.
NationalInstruments.DAQmx.DaqSystem.AddNetworkDevice()
Adds a Network cDAQ device to the system. This method does not attempt to reserve the device after the device is successfully added.
This can be followed up with
NationalInstruments.DAQmx.Device.ReserveNetworkDevice()
Reserves the Network DAQ device for the current host. Reservation is required to run NI-DAQmx tasks, and the device must be added in MAX before it can be reserved. This method does not override any existing reservations on the device.
Please take a look at these and let me know if you have any further questions.
James Duvall
Message 6 of 8
(6,621 Views)
Hey! I`m creating a c++ application and I have a simillar problem. I already included the NIDAQmx.h in the application, but after compile it says "DAQmxReserveNetworkDevice" was not declared in this scope. Do you guys know how to implement this function in a c
++ application?
*Others functions, such as createTask,createDIchannel are working perfectly
Message 7 of 8
(5,522 Views)
I got it. I just added the function in the header and now the function is available. I`m sending the header in attatchement.
Message 8 of 8
(5,508 Views)
