Is there a bug in the scattergraph ticks when x axis scaletype is logarithmic and range minimum is 1e-15
It looks like there is a bug in Scattergraph when  the x axis scaletype is logarithmic and the minimum range value is 1e-15.  See below:
24238i14C276B6FF0C1B7B
It looks like it's only 1e-15 that causes this problem:
24240i1ADB133DBB1EE3C8
Even 1.0001e-15 doesn't cause the problem.
I have attached a project that demonstrates the problem.
Has anyone else seen this problem?  Is there a fix, or a fix in the works?
Stephen
(3,217 Views)
Hello Stephen,
I've reproduced what you're seeing and verified that it is a bug.  I've filed a bug report for this issue with ID 249777.  Unfortunately, there doesn't seem to be a workaround available besides just not picking 1e-15 (or others such as 1e-13, 1e-33, etc) as the range minimum.  We intend to fix this bug for the next release of Measurement Studio.
Thanks for reporting the bug -
NickB
(3,192 Views)
