Is there a way to programmatically change a scale and save it?
Is there a way to programmatically change a scale created in MAX and save it back to MAX?
Joe White
(3,081 Views)
Hello Joe White,
There is a way to programmatically change a scale created in MAX and then save it back.  To create a task from VS and save it, please see the following example program.  If you do want to change an existing scale, you could use something similar to the following code:
LinearScale myScale = (LinearScale)DaqSystem.Local.LoadScale("TestScale");
myScale.Slope = 5;
myScale.YIntercept = 6;
DaqSystem.Local.SaveScale(myScale, "", SaveOptions.OverwriteExisting|SaveOptions.AllowInteractiveEditing|SaveOptions.AllowInteractiveDeletion);
Jesse O.
Applications Engineering
Jesse O. | National Instruments R&D
(3,069 Views)
