Issues with Measurement Studio 2019 extension for Visual Studio 2019
Hello all,
I have been struggling to get the Measurement Studio 2019f1 extension to work properly with Visual Studio 2019 Professional. After successfully installing Visual Studio 2019 Pro (and verifying its functionality) I downloaded and installed Measurement Studio 2019f1 through the NI Package Manager and executed "NationalInstruments.MeasurementStudio.VSIX.vsix" (located in C:\Program Files (x86)\National Instruments\Measurement Studio\VS2019) to make sure the extension was installed. Upon doing this I was prompted with a message stating that this version of Measurement Studio is not compatible with the installed version of Visual Studio 2019, I continued with the installation of the extension and it did end up completing successfully.
Now, when trying to create a new NI Windows Forms Application I am prompted with the error message attached below (Can't get the service: NationalInstruments.MeasurementStudio.Interfaces80.IMsProduct). If I elect to "Allow synchronous autoload of extensions" and then try to create a NI Windows Forms Application, Visual Studio remains indefinitely stuck in the Creating Project window.
From what I've found there should be no problem using Visual Studio 2019 with Measurement Studio 2019f1 so I'm not too sure what else to try. I have already removed and reinstalled both Visual Studio and Measurement Studio.
Any suggestions would be appreciated.
Charlie
(2,829 Views)
i had the same issue and i read this :
https://forums.ni.com/t5/Measurement-Studio-for-NET/Measurement-Studio-2019-extension-for-Visual-Stu...
"...... the only way for the Measurement Studio extension to work under Visual Studio 2019 is to check the checkbox under Extensions->Manage Extensions (Click 'Change your settings for Extensions') Under Options Choose Environment->Extensions and Check 'Allow synchronous autoload of extensions
(2,475 Views)
