Limit the range
Hi to all,.
I apologize if my English is no so good, I hope it's good enough to explain my problem.
I'm quite new to both NI boards and Measurements Studio: I searched in past threads without find a complete answer to my questions.
I have a PCI-6229 DAQ board configured by MAX. Then, I acquire data with Visual Basic .NET. We're speaking about analog input tasks.
My question is: how to actually limit the input range of measured data (possilby in MAX)?
I know I can define the input data range but the actual values may change a little either over or under these limits. I need a sort of "clamping" so if I set say 5V as maximum allowable value and the board read 5,01V I want to read 5V.
Currently I achieve this in my software with several if..then statements for each analog input:
[pseudocode]
if readvalue > MAX then outputvalue = MAX
elseif readvalue < MIN then outputvalue = MIN
else outputvalue = readvalue
However, I'm wondering if I can setup MAX to do this automatically.
Thanks for any answer.
Marco Trapanese
Femtotech
(3,799 Views)
Dear Marco,
Actually what are you seeing is expected behavior. DAQ driver allows a little "over measure",  usually this feature is great for troubleshooting purposes.
Looks like you found a viable solution in Visual Studio.
Altough I'm not a Visual Studio Guru, I'm quite confident you can find some kind of array threshold funtion to get an easier solution.
have a good day.
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(3,784 Views)
I read the 'input range' setting actually doesn't limit in anyway the output values. It just set the closest ADC range. Am I wrong?
However, I need to
exactly limit the output range so I will look at a convenient solution in .NET, as you suggested.
Marco
(3,758 Views)
