MISSING NationlInstruments.Common.DLL - HELP !
Visual Studio 2017
Loading older project file
All ok except the references say it cannot find NationalInstruments.Common.DLL version 8.6.35.131.
I have all the dll's from the older project and it loads all the rest fine
NationalInstruments.Common.DLL                 version  8.6.35.131  -   System cannot find....
NationalInstruments.UI.DLL                            version  8.6.35.189  -   OK
NationalInstruments.UI.Styles3D.DLL             version  8.6.35.189  -   OK
NationalInstruments.UI.WindowsForms.DLL   version  8.6.35.189  -   OK
How to get the  correct DLL !
This is holding the whole project up..
Cheers
(2,459 Views)
Hello
I meet the same problem before.
My way is that, if possible, use the newest framework to compile the code, maybe the newest version is 4.6
It could fix you problem.
It seems NI support good for the newest framework version, but for the old framework version, even the examples do not work also...
(2,404 Views)
