Manually setting the acquisition voltage level on PIXe-6535
How can I manually set the acquisition voltage to 2.5v on a PXIe-6535 using the .NET API? I've gone tearing through the documentation, and I keep coming up empty.
(3,509 Views)
Accepted by topic author CurtisHx
Found it.  It's under the DIChannel.LogicFamily.
        using (NationalInstruments.DAQmx.Task task = new NationalInstruments.DAQmx.Task())
          var chan = task.DIChannels.CreateChannel("PXI1Slot1/Port3/Line3", "", ChannelLineGrouping.OneChannelForAllLines);
          chan.LogicFamily = DILogicFamily.TwoPointFiveVolts;
          /* rest of code...*/
(3,487 Views)
