Measurement Studio 2013 and Windows 10 Compatibility
Anybody successfully using Measurement Studio 2013 on Windows 10 OS? The UI controls are all messed up when I opened my program in Measurement Studio 2013 + Visual Studio 2012 on Windows 10 OS.
(4,954 Views)
According to the following white paper, only Measurement Studio 2015 is supported on Windows 10. That doesn't necessarily mean it won't work, but it will likely be difficult to get to work.
http://www.ni.com/white-paper/52818/en/
Maggie M.
Application Engineer
National Instruments.
http://www.ni.com/support
(4,915 Views)
Thank you. I guess I can upgrade to mstudio 2015. But then I see that the Visual Studio version can be no later than 2013. Are there any work arounds for it to work with Visual Studio 2015?
(4,906 Views)
I see that there was some discussion on the compatibility between VSTUDIO2015 and MSTUDIO2015 in the forum.
And then there is this relevant knowledgebase article on this matter:
http://digital.ni.com/public.nsf/allkb/F01DDED92E62447286257F5E0071048D
Is there any guidance on the projected version update of mstudio though? I don't see any beta testing going on either.
(4,903 Views)
Accepted by topic author Sid05
Information regarding future releases of Measurement Studio is proprietary, unfortunately. Your best bet for now is to use Measurement Studio 2015 with Visual Studio 2013, or follow the KnowledgeBase article for using Measurement Studio 2015 with Visual Studio 2015.
Maggie M.
(4,881 Views)
I have over 100 projects that I support that use measurement studio 2013 (with VS2010 on win 7). If I were to migrate to the current version of measurement studio, how would this impact the projects currently using measurement studio 2013.
Thanks!
(2,710 Views)
