See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> NationalInstruments.VisaNS.VisaException: The resource is valid, but VISA cannot currently access it. VISA error code -1073807246 (0xBFFF0072), ErrorResourceBusy
at NationalInstruments.VisaNS.Internal.ErrorChecker.CheckStatusAndThrow(Int32 status, VisaHandle visaObject)
at NationalInstruments.VisaNS.Session..ctor(String resourceName, AccessModes accessMode, Int32 openTimeout, String expectedResourceName)
at NationalInstruments.VisaNS.SerialSession..ctor(String resourceName, AccessModes accessMode, Int32 openTimeout, Boolean checkResourceType)
--- End of inner exception stack trace ---
at System.RuntimeMethodHandle._InvokeConstructor(Object[] args, SignatureStruct& signature, IntPtr declaringType)
at System.RuntimeMethodHandle.InvokeConstructor(Object[] args, SignatureStruct signature, RuntimeTypeHandle declaringType)
at System.Reflection.RuntimeConstructorInfo.Invoke(BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, Object[] args)
at NationalInstruments.VisaNS.ResourceManager.Open(String resourceName, AccessModes accessMode, Int32 openTimeout)
at My2041Project.VisaTask.OpenSession(String sessionName) in C:\Users\tth\Documents\Different_Tests\NI\MStudio Examples\AWG2041\My2041Project\VisaTask.cs:line 77
at My2041Project.VisaTask..ctor(String sessionName) in C:\Users\tth\Documents\Different_Tests\NI\MStudio Examples\AWG2041\My2041Project\VisaTask.cs:line 91
at My2041Project.VisaTask..ctor() in C:\Users\tth\Documents\Different_Tests\NI\MStudio Examples\AWG2041\My2041Project\VisaTask.cs:line 83
at My2041Project.Form1.button1_Click(Object sender, EventArgs e) in C:\Users\tth\Documents\Different_Tests\NI\MStudio Examples\AWG2041\My2041Project\Form1.cs:line 24
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
