Measurement Studio installation trashed Document Explorer?
I installed the eval version of Measurement Studio a couple days ago.  Now I need to lookup something in the Visual Studio .Net 2005 documentation.  However, all I can get to from Document Explorer (collections under "Filtered By") are for Measurement Studio.  How can I get my .Net documentation back?
Certified LabVIEW Developer
NI-VLM Administrator
(3,339 Views)
Hi JulieC,
If you have MSDN installed then the Filtered By... results should have all of Microsoft's help topics after you install Measurement Studio. However, if you do not have MSDN installed locally on the machine you can get to the Help on Help (which is the only Help that VS 2005 installs) by going to Help->Help on Help from VS 2005.
Test Engineer - CTA
(3,328 Views)
I thought I had MSDN installed locally, but I installed (or re-installed) it and now I can get to my VS docs.  All the same, I could definately get to them before, whether it was online or locally, and installing CVI should not take away that access.
(3,320 Views)
