MeasurementStudio 2013 using VS2012 DAQmx Dependency Problem After Upgrading
Here you go. The directory that it was located in within my computer was:
C:\Users\Public\Documents\National Instruments\MStudioVS2012\DotNET\Examples\Application\Deployment\WiX\All Libraries\Setup
If you run into any more problems while working with it, it would be a good idea to make a new forum post. The thread will get more traffic and then you can mark the forum as resolved when you find the answer to your question.
Best Regards,
-KP
Kurt P
Automated Test Software R&D
Message 21 of 22
(3,080 Views)
Please excuse my english,
I'm using Visual Studio 2012 and I got this problem too. With my collegues, we found a workaround for this problem, but I don't know if it will work for you.
First Step :
- go on C:\Program Files\Common Files\Merge Modules and cut the merge modules involved in your error message
- Paste this modules in a safe place, for exemple in C:\Program Files\Common Files
Second Step :
- Go on the menu "Specify Application Data"
- In the "Files" Page, don't choose all the project output but only the .exe and ressources files you need
Third Step:
- Right click on the .exe file and select "Dependencies from scan at build..."
- Unselect the dependencies you don't need
This works for me, now I can build an installer with installshield.
Jeremy CHIFFE
Certified LabVIEW Architect (2016)
Message 22 of 22
(2,512 Views)
