MessageBasedSession VISA Serial Synchronously
Hello
Microsoft Visual Studio 2010 with Measurement Studio
I have an RS232 interface instrument. I am able to comunicate with it using Measurement & Automation Explorer's Open Visa Test Panel
So I know the hardware path is there..
I am able to Open a session, and able to Write
But the following Read allways times out with
Timeout expired before operation completed. VISA error code -1073807339
At this point I opened up NI Spy
I noticed the  Open Visa Test Panel uses viWrite and viRead, and those work
Where as when I run my program, my MBS apears to be using viWriteAsync and viReadAsync
Is there a way to configure my MBS session to use the SYNC versions instead of the ASYNC version? I see that LabVIEW apears to have this option, but I dont see it in Measurement Studios
But my software allways gets a timeout
(5,402 Views)
Hey grantsenn,
There are some VISA examples that could help solve this issue. The examples are located under :
Start » All Programs » National Instruments » VISA » Examples » DotNET3.5 » SimpleReadWrite » cs
Try looking through the Simple Read and Write examples and see if they help.
Hope this helps!
Wear
Product Support Engineer
(5,379 Views)
