Missing assemblies for Example: GettingStarted.2008 (ModularInstruments)
I am trying to run the examples for"ScopeWithUI" in DotNET/Examples.  These require NationalInstruments.ModularInstrument.Common, NationalInstruments.ModularInstrument..ModularInstrumentsSystem, and NationalInstruments.ModularInstrument.Scope.
I haven't found a message in the forums that corresponds to this question.
Help.
Dick
(4,030 Views)
Accepted by topic author Dick Grier
Hi Dick,
To be able to run the referenced example, you would need to install the NI-SCOPE driver compatible with all NI-SCOPE hardware. Installing the driver will ensure that the appropriate assemblies are located in the Global Assembly Cache.
Best Regards,
Swathi B
(4,014 Views)
Thanks.  I made the (incorrect) assumption that this was a general-purpose example.  I do need to emulate, in some limited way, scope operation (I've got CompactDAQ hardware), so I'll have to look at the more generic examples.
Dick
(4,012 Views)
