Monitoring Analog Inputs to trigger Digital Outputs
Hey All,
I am currently using a USB-6343 DAQ from a .NET application where I continuously monitor data from multiple (1-6) pressure transducers connected to an Analog Inputs, both to 1) plot them to a waveform chart in semi-real time and 2) flip a valve attached controlled by a Digital Output when the pressure reaches a certain threshold, relieving the pressure for a period then closing it, allowing the pressure to build again. I want to do this for a user defined number of cycles.
Thus far, I have been using a producer-consumer model where I used the EveryNSample event to read (produce) from the DAQ buffer placing the readings into Queue, combined with a timer that updates the GUI with the contents of the queue at a slower interval and a thread dedicated to peeking at the last value in the queue to see if my threshold has been met.  If it has I initiate a asynchronous Task that opens the valve, sleeps for the desired time and then closes it.
This process works, but has results in quite a heavy CPU load (task per nest for open/close, dedicated monitoring thread, and thread for reading the values from the DAQ) and I always end up opening the valve a little late.  Any ideas on how to do this faster or more efficiently?
(2,107 Views)
Hello JonathanMcNeil,
Did you try to use another way to communicate data between loops, for instance Channel wires.
 I am also attaching article about getting started with channel Wires. Here is the link.  It might be helpful in this case.
Regards
(2,070 Views)
