MultiPlotCursor value formatting in C# code
How to change MultiPlotCursor value format in C# code?
thanks
Theo
(2,993 Views)
The display of the multi-plot cursor's Values are controlled by the ValuePresenter property. Generally you would use a ValueFormatterGroup, which supports specifying a different formatter for each dimension (i.e. the X and Y data for each value). If the ValueFormatters collection is empty or missing a value, the DefaultFormatter, will be used in its place.
Here is the answer from another question that wanted to display one dimension as time and another as numeric:
<ni:MultiPlotCursor.ValuePresenter>
    <ni:ValueFormatterGroup DefaultFormatter="0.00" Separator=" — ">
        <ni:GeneralValueFormatter Format="yy-MM-dd HH:mm:ss" />
    </ni:ValueFormatterGroup>
</ni:MultiPlotCursor.ValuePresenter>
The equivalent in code:
cursor.ValuePresenter = new ValueFormatterGroup( " — ", new GeneralValueFormatter( "0.00" ) ) {
    ValueFormatters = { new GeneralValueFormatter( "yy-MM-dd HH:mm:ss" ) }
~ Paul H
(2,974 Views)
It worked.
Thank you Paul !
(2,965 Views)
