Multiple Y-Axes slows WaveformGraph down
I want to use multiple y-axes in a WaveformGraph to scale single waveforms without caching all data points and plot them again.
The attached minimal sample shows the behaviour with and without multiple y-axes. In the screenshot “MultiAxes.png” each waveform has its own y-axis. In the screenshot “SingleAxis.png” all waveforms use the same y-axis. Without using multiple y-axes the time to reconfigure the graph reduces from 3.3 seconds to 0.5 seconds.
How can I shorten the time to rebuild the WaveformGraph without omit use of multiple y-axes?
Stephan
(5,421 Views)
Hi Stephan,
Would you please give me the details about which Visual Studio/Measurement Studio you are using?
Best regards
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(5,385 Views)
Hi Christoph,
I am using Visual Studio 2012 and Measurement Studio 2013.
Stephan
(5,364 Views)
Hi Stephan,
I would like to point you to the source code. There you see a clear difference in behaviour between only one axis and multiple axes. The for loop runs either 1 or number of waveforms (e.g. 200) which should account for a difference in computation time.
if (true == mMultiAxesCheckBox.Checked)
	axesCount = mWaveformCount;
else
	axesCount = 1;
for (int i = 0; i < axesCount; i++)
	var yAxis = new YAxis();
	SetAxisInvisible(yAxis);
	yAxis.Range = CalcRange(i, 1.0);
	yAxis.OriginLineVisible = true;
	yAxes.Add(yAxis);
	//mGraph.YAxes.Add(yAxis);
Best regards
Christoph
(5,361 Views)
Hi Christoph,
Thank you for your fast answer.
As you can find in row "Axes created" of the following table the loop you point to consumes only 12 ms of the CPU time.
Axis Count
1 Axis
200 Axes
200 Axes without optimization
Clear axes
14 ms
943 ms
2796 ms
Axes created
0 ms
12 ms
7 ms
Axes added
1 ms
453 ms
2373 ms
Clear plot
40 ms
372 ms
2336 ms
Waveforms added
37 ms
393 ms
2338 ms
Plot samples added
113 ms
106 ms
109 ms
Clear annotation
25 ms
360 ms
2312 ms
Annotations added
281 ms
657 ms
2650 ms
Total
535 ms
3312 ms
14938 ms
The problem is that all actions on the graph take much longer if I add multiple axes however the amount of plotted data is the same.
I am searching for a optimization like I have used in the method SetAxisInvisible(). See the lines after the comment in the following code snipped. The time behaviour without this optimization I have added to the table above in column "200 Axes without optimization".
private void SetAxisInvisible(Axis axis)
	axis.Visible = false;
	axis.Mode = AxisMode.Fixed;
	// the following lines doesn't change anything on the appearance of the axis because
	// the whole axis is invisible but they improve the performance of the graph drastically
	axis.AutoSpacing = false;
	axis.CaptionVisible = false;
	axis.EndLabelsAlwaysVisible = false;
	axis.MajorDivisions.GridVisible = false;
	axis.MajorDivisions.LabelVisible = false;
	axis.MajorDivisions.TickVisible = false;
	axis.MinorDivisions.GridVisible = false;
	axis.MinorDivisions.TickVisible = false;
Stephan
(5,354 Views)
