My program does not install properly in Windows 7. The National Instruments files do not install.
Pete,
Are you using ClickOnce Deployment? This is a Visual Studio tool that is not supported by Measurement Studio. Check out the KB article that describes its support. The main problem with ClickOnce is that it does not write to the registry. This sounds just like the problem you are experiencing. Instead, follow the deployment procedure in the Measurement Studio help that requires building a setup project.
Message 11 of 12
(938 Views)
The solution was that I needed to install NIDAQ core Run TIme.  I missed that in the doumentation.
Pete@ITC
Message 12 of 12
(922 Views)
