.NET 2.0 API for 32-Bit Application
I have a machine with Windows Embedded 7 installed and following software:
I cannot install software on this machine. My application should communicate with Tektronix oscilloscope using the above software.
Which DLLs should I use? It could be nice to see some examples.
(4,504 Views)
What kind of machine is this, and why can't you download additional software to it?
If you're using Measurement Studio to communicate between the two instruments, you probably need an instrument driver. You can search for the model of your Tektronix oscilloscope on the 3rd party instrument drivers page to find the correct driver to download.
Francine P.
Applications Engineering
(4,477 Views)
It is some kind of RT machine and it has no space available to install anything.
I have tried to use TekVISANet successfully, but TekVISA officially does not support Windows Embedded. Even if it works for me now, I am afraid to bump into problems in future.
(4,472 Views)
I can use NI-VISA. I just need NationalInstruments.Common.dll and NationalInstruments.VisaNS.dll built for .NET 2.0 and 32-bit OS.
(4,471 Views)
I was able to find NI-VISA libraries for .NET 4.0 and 32-bit OS. It works fine on the installed software.
(4,468 Views)
To clarify, is it working now with NI-VISA libraries for .NET 4.0 and 32-bit OS installed?
Francine P.
(4,447 Views)
Yes.
(4,437 Views)
