NI 4070 function card measures current above 10A
Hey,
Recently I try to measure a current which is about 10A, but I feel worry because my NI driver NI 4070 could only measures the current which is below 1A, as the spec said. Is there any solution to investigate this issue?
Thanks in advance if there is any discussion or good idea about this topic.
(2,495 Views)
Maybe you can connect a resistance about 10 Ω and measure the voltage, then you can figure out the current value.
(2,466 Views)
