NI DAQ MAX Receiving false results from Task.CIChannels.CreateAngularEncoderChannel()
I have an NI DAQ: cDAQ9185, with two slots: NI 9361, and NI 9205. I'm trying to read data from port ctr1 of NI 9361 as a counter channel: AngularEncoderChannel. I'm using NI's C# api.
All I receive back is a stream of 0, 0.36, 0.72 in bulks (a few thousand times 0, then a few thousands more 0.36 and so on), while I'm expecting values of about 2000, constantly changing.
The physical wiring are fine. I ran the code from the angular encoder example, and it works good. I changed all my Task configurations to be as similar as possible to the example, but it still does not work.
My Code:
protected ConcurrentQueue<Sample[]> _exportingQueue;
public double SampleRate { get; set; }
public NITask.Task Task { get; protected set; }
public long SampleCounter { get; set; }
private string _cPort = "cDAQ9185-1E7661EMod1/ctr1";
private NITask.CounterMultiChannelReader _reader;
public void InitializeTask()
                Task = new NITask.Task();
NITask.CICountEdgesActiveEdge.Rising, 0, NITask.CICountEdgesCountDirection.Up);
Task.CIChannels.CreateAngularEncoderChannel(_cPort, "", NITask.CIEncoderDecodingType.X1, false, 0, NITask.CIEncoderZIndexPhase.AHighBHigh, 24, 0.0, NITask.CIAngularEncoderUnits.Degrees);
                Task.Timing.ConfigureSampleClock("", SampleRate, NITask.SampleClockActiveEdge.Rising,
                    NITask.SampleQuantityMode.ContinuousSamples, 1000);
                // Create a variable of type CountReader which will read the task's Stream property.
                _reader = new NITask.CounterSingleChannelReader(Task.Stream);
        protected override void ReadData()
            double readerData = _reader.ReadSingleSampleDouble();
            Sample[] singleSample = new Sample[1];
            singleSample[0] = new Sample(readerData, SampleCounter);
            _exportingQueue.Enqueue(singleSample);
            SampleCounter++;
The Sample object, and the _exporterQueue are not critical for the actual function of this program. I'm keeping them here just in case they're surprisingly related nonetheless. Sample is an object with a {double Data, and int SampleCounter}, and the _exportingQueue is a queue which stores the samples and dequeues them through another thread. Also I have an alias for the Task object of NI as NITask, just because I'm working with threads, so that the two Task objects won't clash.
I hope the question is clear enough.
Thank you very much!
Message 1 of 1
(1,512 Views)
