NI-DAQ Multiple channels
I wrote following code to simulate voltage values of 2 aircraft throttles. Retrieving the data for the first one is no problem, the voltage appears correcly (dev1/a0 --> ENG1ThrottleData(0, 0)). However the data for dev1/a1 is completely wrong. Can somebody tell me what i did wrong? (changing the ENG1ThrottleData(1, 1) did not help. I guess it has something to do with the multiple channel reading, but can't find a solution.
Thanks in advance,
Public Sub OnDataReady(ByVal i As IAsyncResult)
'Retrieve the data that was read.
'At this point, any exceptions that occurred during the asynchronous read are thrown
Dim Result As Integer
Dim ENG1ThrottleData As Double(,)
ENG1ThrottleData = ENG1ThrottleReader.EndReadMultiSample(i)
Dim ENG1ThrottleVoltage As Double = ENG1ThrottleData(0, 0)
lblVoltageENG1.Text = ENG1ThrottleVoltage
Dim ENG2ThrottleVoltage As Double = ENG1ThrottleData(1, 1)
lblVoltageENG2.Text = ENG2ThrottleVoltage
ENG1ThrottleReader.BeginReadMultiSample(100, AddressOf OnDataReady, Nothing)
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
'ENG1Throttle
ENG1ThrottleTask.AIChannels.CreateVoltageChannel("dev1/ai0,dev1/ai1", "", AITerminalConfiguration.Rse, -10, 10, AIVoltageUnits.Volts)
ENG1ThrottleTask.Timing.ConfigureSampleClock("", Convert.ToDouble(1000), SampleClockActiveEdge.Rising, SampleQuantityMode.ContinuousSamples, 1000)
ENG1ThrottleTask.Control(TaskAction.Verify)
ENG1ThrottleReader =
New AnalogMultiChannelReader(ENG1ThrottleTask.Stream)
ENG1ThrottleHandle = ENG1ThrottleReader.BeginReadMultiSample(100,
End Sub
Message 1 of 1
(4,016 Views)
