NI DAQ interactions with a temperature control unit
Unfortunately, I will not be able to provide a screenshot or exact data. But here's the issue. We're needing to run a 5V PWM from an Arduino uno r3 through a Wavelength Electronics PTC K-CH 5. When hooking up the DAQ to the unit it's been reading as a certain voltage equivalent but once disconnected and reconnected, the value changes, any suggestions? When checking online, the most frequent solution has been an RC Filter.
(1,957 Views)
Simple circuit diagram of the connections will be helpful to guide you better.
Santhosh
Soliton Technologies
(1,883 Views)
