NI488.2 C# Device.Notify() Example Does Not Execute Device Notify - Why Doesn't the Device.Notify() callback work with GpibStatusFlags.DeviceServiceRequest?
I am working on a driver that required an event raised back whenever a device's SRQ line is asserted. Sounds simple enough, and the Device.Notify() method should fit the bill. However, I am finding that only the Board.Notify() method (using the GpibStatusFlags.ServiceRequest) works, and not the Device.Notify() method (using GpibStatusFlags.DeviceServiceRequest). There are two possibilities that I can think of:
1) The auto serial pool flag is disabled  - can't figure out where the flag is set.
2) This is not supported by the instrument - Not sure why that would be the case.
I don't think it's my software (famous last words), because the example supplied by NI does not work as well. The example can be found at:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-488.2\Languages\DotNET2.0\Notify\cs
for a "standard" NI488.2 installation.
Has anyone successfully used Device.Notify() in a .NET application, preferable C#? Can you offer some words of advice on what may be the problem?
Dave
Software Details:
NI488.2, version 2.52
Microsoft Visual Studio 2005 (FW2)
Hardware details:
Windows XP/SP2
NI488-USB-HS
Keithley 2602
(4,560 Views)
Dave,
When you say "it doesn't work," what exactly do you mean?  Do you receive an error or warning, or does it just silently fail?
Chad B. » National Instruments » ni.com
(4,542 Views)
