NI4882 equivalent command for the IVI formatted488IO ReadList command.
I need an NI4882 equivalent command for the IVI formatted488IO ReadList command.
This is what I have:
using Ivi.Visa.Interop;
using Ivi.Driver.Interop;
formatted488Class = new FormattedIO488();
formatted488Class.WriteString("LDATA");
object response = formatted488Class.ReadList();
What I need is an equivalent when instead of the IVI DLLs (Ivi.Visa.Interop and Ivi.Driver.Interop), I want to use NationalInstruments.Common, NationalInstruments.NI4882 and NationalInstruments.VisaNS.
I.e.:
NI4882.Device.Write("LDATA");
and then call:
NI4882.Device.ReadString() or NI4882.Device.ReadByteArray()
Problem is I don't know how many bytes or strings are to be read, and even if i knew it would not help because it would still not behave the same way as IVI's Readlist.
Can anyone point me in the right direction?
Cris
(5,092 Views)
All you need to do is to do is to use NI4882.Device.ReadString();
(5,083 Views)
Yes, I was using ReadString. Unfortunately, it only returns 128 values of 1000, which is what I need. If you do not specify the number of values to read, i.e,. ReadString(int numberOfBytes), it assumes a default number of 128. However, I found a solution which is more of a workaround. I read the first 128 values, and it so happens that the instrument returns as a first value the number of values to be read (1000). So I read the rest of the values in a loop. Not elegant, but it seems to work for me.
(5,071 Views)
