NI9237 The voltage output range of your sensor does not overlap with the voltage input range of your measurement device
When I run a inputTask,appera some errors like below.
Measurement device cannot acquire data from the sensor in its current configuration. The voltage output range of your sensor does not overlap with the voltage input range of your measurement device.
If your measurement device supports different gains or input ranges, try using a lower gain or a wider input range. If the device has a fixed gain/range, you might need to change sensor attribute settings such as Excitation Value or use a measurement device that supports a wider voltage input range.
Device: cDAQ1Mod1
Task Name: inputTask
Status Code: -200357
Do you has been meet these,how to deal them?
Message 1 of 1
(2,040 Views)
