NIDCPower: Specified property cannot be set while the task is running. What's the task that's running?
I'm trying to get measurements on a PXIe4139, and I can't set the AperatureTime property.  Here's the exception I get:
Ivi.Driver.IviCDriverException was unhandled
  ErrorCode=0
  HResult=-2146233088
  Message=ModularInstruments.NIDCPower: Specified property cannot be set while the task is running.
Set the property prior to starting the task, or stop the task prior to setting the property.
Property: Aperture Time
And the code, in it's entierty...
      power = new NIDCPower("PXI5Slot3", false, true);
      power.Outputs["0"].Source.Output.Function = DCPowerSourceOutputFunction.DCVoltage;
      power.Outputs["0"].Source.Voltage.VoltageLevel = voltage;
      power.Outputs["0"].Source.Output.Enabled = true;
      power.Outputs["0"].Measurement.ApertureTime = 0.000001;
      power.Outputs["0"].Measurement.SamplesToAverage = 0;
      while (true)
        var measurement = power.Measurement.Fetch("0", new NationalInstruments.PrecisionTimeSpan(1.0), 1);
        Console.Writeline(measurement.VoltageMeasurements[0]);
        Console.Writeline(measurement.CurrentMeasurements[0]);
What am I missing?
(3,322 Views)
While I am more directly familiar with LabVIEW's API for the 4139, I believe the error comes from trying to change a setting after you've configured and enabled the output. Try placing the aperture time setting above the enabled line.
Finch Train
(3,293 Views)
